ERROR:DesignEntry:239........BUS TAP connection
hello...
i connect the BUS TAP and i got error
ERROR:DesignEntry:239 - mux_f_ip.sch Incorrect bus tap at (528 432 528 528): destination branch  is not part of the source branch
Anyone suggest me how i resolve this problem..........
pls help
Re: ERROR:DesignEntry:239........BUS TAP connection
you need to add the correct wire names to the connected lines.
e.g. if your bus is named Data(7:0)
then the wire comming out of the tap needs to be named Data(0) for instance.
There are some very helpful items in the options field for naming wires (e.g. auto increment of the wire number)
see the manual for details.
Have a nice synthesis
  Eilert
