nibal
Elaboration warning
I get the following warning from elaboration:
[BD 41-702] Propagation TCL tries to overwrite USER strength parameter In2_width(14) on '/cap_db0_rx0' with propgated value(1). Command ignored
In2 should be 14 wide according to my flow. Why does TCL try to reduce it to 1? I hope TCL is igmored.
Attaching BD screenshot.
TIA
Nikos
genelatham
I can't tell you how frustrating it is to finally find a mention of the error I'm having only to find no one ever responded to the problem.
Sorry I can't help you.  Did you ever get a solution?
anusheel
@genelatham
Can you post the exact error message and more details of the design? If possible, share the small test case for us to reproduce the issue.
Anusheel
Helpful answer -> Give Kudos
genelatham
I'm afraid I can't do either of these things.  The problem I had was with an AXIDMA controller.  I resolved the problem by deleting the controller block and adding the IP back and reconfiguring it.  I have tried to recreate the problem in a simple design and have not been able to.
Sorry,
Gene
