Visitor wizard16888
Encrypted netlist run through with error "ERROR: [Common 17-70] Application Exception: AttrType mismatch, given String wanted Int"
We are using the ultraScale+ device xcvu13p, using Vivado 2018.1 to do encrypt netlist based synthesis/P&R.
we keep hit one error and Vivado crash with
"Application Exception: AttrType mismatch, given String wanted Int" even local FAE pointed out that there is a bug for memory mmi writing got fixed in 2019.1 version. and set the workaround in Vivado of.
" set_param memdata.allowXPMROMBRAMS 1".
Here attach the vivado.log.
Henry
