Visitor jaydee
Error: [Common 17-53] User Exception: Failed to create a term in HANRVeriTranslator::importPortInfo
Hello guys,
I am getting this Message while open a post-synthesis verilog-netlist in Vivado 2015.4.
Does anybody now what this message mean?
My work for more information:
I am working on an extended Leon3 - Processor and in my workflow i need to write the netlist into a verilog file and after that i need to read the verilog-file as a post-synthesis netlist into vivado. I am not changing anything in the netlist.
Can anybody help me with this message?
I cannot find information on this topic.
Thanks guys.
Cheers Dennis
Re: Error: [Common 17-53] User Exception: Failed to create a term in HANRVeriTranslator::importPortInfo
Hi @jaydee,
There were few known issues regarding this error and have been fixed in later Vivado versions.
So, can you please try migrating to the latest Vivado version and please let us know if you are still facing the same error in latest Vivado version too.
Thanks & Regards,
A.Shameer
Hi @jaydee,
Thanks & Regards,
A.Shameer
Hello @jaydee,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
