polyee13
Error HSI 55-2023 when System_ILA is used in BD.
I have this weird phenomenon in Vivado 2020.1 if I use a System_ILA core in my bd it prevents the xsa from successfully being created. I noticed this back in Vivado 2018.3 as well when attempting to create an fsbl with our scripting. If I use a regular ILA it works fine. If I remove the System ILA I can successfully write out the .xsa as well.
INFO: [Vivado 12-4895] Creating Hardware Platform: tests.xsa ...
ERROR: [Hsi 55-2023] No IPI block design hardware handoff files present in the hardware definition file test/par/vivado/.Xil/Vivado-13826-machine/HWH/temp.hdf
ERROR: [Pfi 67-8] Hardware Design is not available
INFO: [Vivado 12-4896] Successfully created Hardware Platform: test/par/vivado/test.xsa
ERROR: [Common 17-39] 'write_hw_platform' failed due to earlier errors.
syedz
@polyee13
Not sure if it applies but I found this answer record which suggests creating an RTL wrapper on BD which could help for such error.
https://www.xilinx.com/support/answers/70160.html
--Syed
