Error Loading Project
When I attempt to create a new project, right when I create it I get an error. ERROR: [Common 17-539] failed to load tclapp initializer can't find package. Any idea how I could fix this? Thanks in advance.
Re: Error Loading Project
Hello @eriksparschu,
Please check https://www.xilinx.com/support/answers/62908.html.
Please follow the below steps to apply the workaround.
1. Open a command prompt,
2. migrate to C:\Xilinx\Vivado\2015.1
Ex: CD C:\Xilinx\Vivado\2015.1
3. Run settings64.bat.
4. Now run vivado -mode tcl once that is opened run command: "tclapp::reset_tclstore" and check if this helps.
Try setting the following environment variable as follows and then see the behaviour.
 XILINX_LOCAL_USER_DATA no
As we have seen other users setting that environment variable that avoided the issue for them.
Thanks & Regards,
Naveen
Kindly note- Please mark the Answer as "Accept as solution" if the information provided is helpful.
Give Kudos to a post that you think is helpful and reply oriented.
