ALi-Natiq
Error message on Minized Board
i got this error message (it is not a warning but an error) :
[Board 49-71] The board_part definition was not found for em.avnet.com:minized:part0:1.2. The project's board_part property was not set, but the project's part property was set to xc7z007sclg225-1. Valid board_part values can be retrieved with the 'get_board_parts' Tcl command. Check if board.repoPaths parameter is set and the board_part is installed from the tcl app store.
watari
Hi @ALi-Natiq
Refer the following URL.
https://github.com/Avnet/bdf
Best regards,
watari
Hi @ALi-Natiq
Best regards,
ALi-Natiq
@watari
Thank you so much sir.
This solved my problem.
Have a nice day and kind regards.
foreignpara
after copy relevant boards_file, there is still the error,how to solve it
the error comes "ERROR: [Board 49-71] The board_part definition was not found for em.avnet.com:microzed:part0:1.0. The project's board_part property was not set, but the project's part property was set to xc7z010clg400-1. Valid board_part values can be retrieved with the 'get_board_parts' Tcl command. Check if board.repoPaths parameter is set and the board_part is installed from the tcl app store."
