Visitor eugeth20
FIFO Generator v.13.2 Data count
Good morning,
I am exploiting the FIFO Generator v.13.2 with the following configuration:
- Data length 32-bit R/W, FIFO length is 4096, Native I/F;
- Independent Clocks, Block RAM implementation, 2 sync stages;
- FWFT behaviour, synchronized reset with security circuit;
- No programmable full/empty thresholds.
As depicted from the attached picture, the wr_data_count/rd_data_count behaviour when the FIFO is empty is quite weird: while writing, count goes up to 1, then goes down back to 0, and eventually remains stuck at N-2 (i.e., if 1024 words were written, wr_data_count and rd_data_count are stuck at 1022).This behaviour is registered with both simple and more accurate data counts settings. Any suggestions?
Thanks in advance!
Eugenio
Scholar drjohnsmith
Re: FIFO Generator v.13.2 Data count
also look at page 111 on the 'strange' actions of these counters..
https://www.xilinx.com/support/documentation/ip_documentation/fifo_generator/v13_1/pg057-fifo-generator.pdf
Perosnaly, I only ever use them as indicatoins, and use the prograbable flags if I want a specific under / over marker.
Scholar drjohnsmith
Due to the nature of how the read / write counters need to work across the two clock domains,
    I understand the documents on the fifos says to only use these as indicators or such like,
       you should use the full / empty flags to know when to read / write the fifo,
Visitor eugeth20
Hello drjohnsmith,
thank you for answering. I do understand that counters belong to different clocks domains, but I do not see why they should decrease during write-only operations.
Best regards.
Scholar drjohnsmith
have a look at the dat asheet,
page 18 for instance,
"The count is guaranteed to never under-report the number of words in the FIFO, to ensure you
never overflow the FIFO. The exception to this behavior is when a write operation occurs at the rising edge of wr_clk/
clk, that write operation will only be reflected on wr_data_count at the next rising clock edge.
If D is less than log2(FIFO depth)-1, the bus is truncated by removing the least-significant bits."
Scholar drjohnsmith
Visitor eugeth20
Thank you for your explanation, I just wished the datasheet provided some more useful examples as it is not clear at all which behaviour is to be expected.
Best regards.
Eugenio
