Fixed point
I'm trying to implement a project using fixed point number but i didn't find the Fixed_PKG package in the packages defined under IEEE library in Vivado 14/15 . so what i have to do to make this package work?
Re: Fixed point
HI mo7amed_elhady@yahoo.com
using this will do.
ieee.std_logic_1164.all;
ieee.numeric_std.all;
library ieee_proposed;
ieee_proposed.fixed_pkg.all;
refer page 190 of UG901
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug901-vivado-synthesis.pdf
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
Re: Fixed point
Vivado 2016.1 does have fixed_pkg
checkout
C:\Xilinx\Vivado\2016.1\data\vhdl\src\ieee_2008
C:\Xilinx\Vivado\2016.1\data\xsim\vhdl\ieee_2008
Bharath
Re: Fixed point
Re: Fixed point
using this will do.
Bharath
Re: Fixed point
Many thanks
