jonaro26
Folder Access Permision Settings
I tried to create a new project but it couldn't work at all.
A message box came up on the screen like...
Create Directory Error Failed to create the directory 'C:/Users/AppData/Roaming/Xilinx/Vivado/project_1'
Please check your folder access permission settings.
How can I change the folder access permission? The user have all permissions in this pc
surajc
Hi @jonaro26,
This has nothing to do with Vivado it is an OS related issue.
The reason for this that the current user ( in Windows OS ) does not have permissions to write to the location mentioned in the error message.
I recommend you to try to create the new project in another location where the current user has all the permissions.
--Suraj
watari
Professor
Professor
Hi @jonaro26
I suggest you to make sure the followings.
- Account name on Windows.
- Does it have non alphabetic character ? If yes, create new account without non alphabetic character.
Best regards,
