Visitor rajesh_s
GUI fails to open after installing 2019.2 on Ubuntu 18.04.3 LTS
I've just made a fresh install of 2019.2 on Ubuntu 18.04.
I've also sourced Vivado/2019.2/settings64.sh
However, when I try invoking the GUI, I get this error
rajesh@mypc:~$ vivado
****** Vivado v2019.2 (64-bit)
  **** SW Build 2700185 on Thu Oct 24 18:45:48 MDT 2019
  **** IP Build 2699827 on Thu Oct 24 21:16:38 MDT 2019
    ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
start_gui
ERROR: [Common 17-267] Couldn't open 'libjvm.so': 'libjvm.so: cannot open shared object file: No such file or directory'
Make sure you are using a supported OS of RHEL5.x or greater.
ERROR: [Common 17-211] Error loading jvm.
Vivado%
Vivado%
What could I be missing here?
Thank you for your time.
Rajesh
Observer tobeychris
Xilinx Official Answer Record
Official Xilinx AR73047
Solution
During the install there are files that do not have the appropriate user permissions for other users to launch the tools.
To correct this, use the following commands on the install directory to copy the group permissions to the user permissions.
Note: if the install was done with sudo, these commands should be run with sudo.
Vivado Install:
chmod -R o=g <install_dir>/Vivado/2019.2/tps/lnx64/jre9.0.4
chmod -R o=g <install_dir>/.xinstall/Vivado_2019.2/tps/lnx64/jre9.0.4
Vitis Install:
chmod -R o=g <install_dir>/Vitis/2019.2/tps/lnx64/jre9.0.4
chmod -R o=g <install_dir>/.xinstall/Vitis_2019.2/tps/lnx64/jre9.0.4
Visitor rajesh_s
Re: GUI fails to open after installing 2019.2 on Ubuntu 18.04.3 LTS
Okay the issue is not with dependencies. Looks like it's to do with ownership of files.
I went to "cd /opt/Xilinx/Vivado/2019.2/bin" and then tried to invoke vivado using "sudo ./vivado" and it works as expected. The GUI opens without any issues.
I had used the following to avoid having to use sudo everytime I need to use Vivado
sudo chown -hR $USER:$USER $HOME/.Xilinx/
 Is sudo always needed? What's the recommended way to go about this?
Rajesh
Observer wgabor
My fixes:
sudo chmod 755 -R /opt/Xilinx/Vitis/2019.2
sudo chmod 755 -R/opt/Xilinx/Vivado/2019.2
Observer wgabor
Note, this is an _ugly_ _hack_, hopefully won't break anything.
Hello @rajesh_s,
Indeed, this behaviour is due to the read write and execute permissions currently set on /opt/ folder.
The default installation path on Linux is /opt/Xilinx, and for most users root privileges is required to write to /opt.
To work around this issue users can either do the following (this is prior the Vivado/Vitis installation):
sudo mkdir /opt/Xilinx
sudo chmod 777 /opt/Xilinx
Now you have read, write and execute permissions to install as any user and any user can then run the installer as themselves (without sudo).
Or, if the tools are already installed, then, as correctly suggested by @wgabor , you can set the correct read, write and execute permissions (sudo chmod 777) or just read and execute permissions (sudo chmod 755) in this case, and you can overcome this issue then.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Observer wgabor
Note:
NEVER do chmod 777 on any files, if possible.
You don't want to give write permission for EVERY user on your system for a given file. Shall I mention the security issues of this?
755 is more than enough in this case.
I think your solution will only work for the user who did the installation not the others, which is major issue.
Moreover, I don't think that chmod 755 (or even worse: 777) is a solution because it adds execution permission to all the files in the install directory. It is nearly as dirty as running Vivado/Vitis with sudo.
Observer wgabor
As I said in https://forums.xilinx.com/t5/Design-Entry/GUI-fails-to-open-after-installing-2019-2-on-Ubuntu-18-04-3-LTS/m-p/1039252/highlight/true#M22381: dirty hack.
You can try to find every .so file (I tried that too), but it was still not enough, so I came up with this quick workaround. Clearly Xilinx should fix it... (seems they have some serious testing issues considering this bug and https://forums.xilinx.com/t5/Design-Entry/Vivado-2019-1-java-error-on-start-gui-with-multiple-monitors/td-p/983998 ...
Note: this problem did not arise on my home PC with Arch Linux.
The Vivado 2019.2 installation copies files into /tools/Xilinx by default, with permissions 750, meaning full read/write/exec permissions for the installing user (normally root), read/exec permissions for the group, and none for all others. This is different from previous installations, where 755 was the norm for all files in the install, and means that if root did the installation, all users could read and execute the installed files.
So there's a few things to try to fix in this installation.
a) Before the install, set the installation directory permissions to a permissible user-group-others setting. For example, user 'admin', group 'users' such that all users in the system belonging to 'users' group can access Vivado.
b) After the installation is done, change the group permissions to a common group, such as 'users'. A simple command would suffice:
sudo chgrp -hR users /opt/Xilinx/
c) Change all files in installation that don't have read permissions for 'others', to have 'others' read/exec permissions. For example:
find /opt/Xilinx/ -type f ! -perm -o+r -print -exec chmod o+rx '{}' \;
Any of these options should work around the issue. I believe Xilinx should fix these permissions to be the same as previous installs.
-Pat
https://tuxengineering.com
Thanks @patocarr
Option C in your post with the modified command to only modify files under /opt/Xilinx/Vivado/2019.2 solved the problem for me.
find /opt/Xilinx/Vivado/2019.2 -type f ! -perm -o+r -print -exec chmod o+rx '{}' \;
Shant
Observer tobeychris
This only needs to be applied to the files under:
/opt/xilinx/Vivado/2019.2/tps/lnx64/jre9.0.4
Fixing the permissions on that folder (or copying that folder from 2019.1) was all that was required to fix the install for us.
Observer tobeychris
Solution
Vivado Install:
Vitis Install:
We now have an Answer Record on this issue with the necessary chmod commands to allow the tools to launch:
https://www.xilinx.com/support/answers/73047.html
Please don’t forget to reply, kudo, and accept as solution!
