Generate Synthesized Design checkpoint
After Vivado, when customize a IP core, it will warn that if "Generate Synthesized Design checkpoint".
what is it used for? Which document give specific explanation about .dcp file?
Thanks!
Re: Generate Synthesized Design checkpoint
This option is by default enabled in vivado 2013.3 for some of the IP cores. This option runs synthesis on the IP assuming it as OOC module (no io buffers inserted) and generates a DCP for it. This Design Checkpoint (DCP) file contains constraints and post synthesis netlist for IP.
When top level synthesis is run, it picks up the synthesized DCP of the IP and runs synthesis only on other logic (synthesis is not run on IP again).
For more details refer to page-33 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug892-vivado-design-flows-overview.pdf
Deepika.
Deepika.
Deepika.
Deepika.
You can use the synthesis DCP files in Vivado Design Suite
designs to speed synthesis of reused IP cores, and in third party synthesis tools to provide netlists for black box IP.
Refer to http://japan.xilinx.com/support/documentation/sw_manuals_j/xilinx2013_3/ug939-vivado-designing-with-ip-tutorial.pdf
Thanks,VIjay
Thanks,Vijay
Hi vemulad,
thank you for your reply.
I also want to know what is OOC (out -of -context)?
Check the following user guide
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug905-vivado-hierarchical-design.pdf
Check the following link also. http://forums.xilinx.com/xlnx/board/crawl_message?board.id=Hier_Des&message.id=905
