Anonymous
Not applicable
Generate output products or Create HDL Wrapper - which one to run first ?
I have practically implemented two Hello Word application on ZYNQ development board. In the first application I have "Generate Output Products" first then "Create HDL Wrapper" followed by Synthesis, Implementation, Bitstream, and Launch SDK … BOOT.BIN
In the second application I have "Create HDL Wrapper" first and then "Generate Output Products" followed by Synthesis, Implementation, Bitstream, and Launch SDK … BOOT.BIN
Both application works but I am wondering which is the correct sequence, Generate Output Products first or Create HDL Wrapper first ? or it depend on application ? or one covers the other ? like Generate Bitstream covers Synthesis and Implementation.
syedz
@Anonymous
No, Create HDL wrapper will not do generate output products. Please check Step 9 in the following link from the Tutorial:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug995-vivado-ip-subsystems-tutorial.pdf#page=36
--Syed
dpaul24
@Anonymous,
I always generate o/p products first followed by HDL wrapper generation and further....!
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
syedz
@Anonymous
It shouldn't matter. I always select "Let Vivado manage wrapper and auto-update" when creating HDL wrapper.
The wrapper file created using this method is automatically updated every time output products for the block design are generated, to reflect the latest changes.
--Syed
Anonymous
Not applicable
This means that "Create HDL Wrapper" covers "Generate Output Products" and there is no need to run "Generate Output Products" provided we select "Let Vivado manage wrapper and auto-update" when creating HDL wrapper.
syedz
@Anonymous
--Syed
