Visitor xenix0711
Generating libraries for processor: microblaze_0 --> Permission denied (EDK 11.4)
 Hello All,
I came accross this issue when i was generating Libraries for MB and i cannot find any answers,
- Generating libraries for processor: microblaze_0 --
ERROR:EDK:1278 - Failed to create directory D:\memeth\microblaze_0\libsrc\.
rm: cannot change to directory `libsrc/common_v1_00_a/src': Permission denied
rm: cannot remove directory `libsrc/common_v1_00_a': Directory not empty
rm: cannot change to directory `libsrc/intc_v1_11_a/src': Permission denied
rm: cannot remove directory `libsrc/intc_v1_11_a': Directory not empty
rm: cannot change to directory `libsrc/standalone_v2_00_a/src': Permission denied
rm: cannot remove directory `libsrc/standalone_v2_00_a': Directory not empty
rm: cannot change to directory `libsrc/uartlite_v1_14_a/src': Permission denied
rm: cannot remove directory `libsrc/uartlite_v1_14_a': Directory not empty
rm: cannot remove directory `libsrc': Directory not empty
make: *** [microblaze_0/lib/libxil.a] Error 2
Done!
Thank you in Advance
Xenix
Re: Generating libraries for processor: microblaze_0 --> Permission denied (EDK 11.4)
I recall running into a similar problem some time ago - it had to do with the specified folders being created without write permissions. Try pointing at the folders in question in Windows Explorer, right-click, choose Properties, and then play around with the settings on the Security tab (might be named differently though - I'm on a Danish WinXP here;).
Message Edited by sonicwave on 02-01-2010 12:22 AM
Visitor nadidjka
Hello Xenix,
I've had a similar problem today but i was able to fix it, try to do the following:
close any opened file under this directory : yourprojectname/microblaze_0
then delete all the files in it (in case there was) and try to generate lirbaries and BSPs all over again.
Hope it will work with you :)
Good luck
Message Edited by nadidjka on 02-05-2010 03:03 PM
Nadidjka
