How instantiate one Block Design inside of another one?
Hi All,
Is it possible to maintain several Block Designs in the Project?
Is it possible to insert/instantiate one Block Design inside of another Block Design?
I guess the inserted/instantiated Block Design should create an additional hierarchy in the "top" Block Design.
So how to do so?
Thank you!
@dmitry1417
Refer http://www.xilinx.com/support/answers/59355.html on hierarchical block designs
Sravanthi
Check this link:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug994-vivado-ip-subsystems.pdf
https://forums.xilinx.com/t5/Design-Entry/Packaging-custom-IP-with-block-designs/td-p/558247
http://www.xilinx.com/support/answers/57546.html
Thanks and Regards
Balkrishan
