pavel_47
Voyager
Voyager
How specify port "non-connected" in block diagram
Can we somehow specify the port "not connected" to allow Vivado to generate a bitstream?
hongh
Hi, @pavel_47 ,
What error do you see during write_bitstream with port unconnected in BD?
dpaul24
@pavel_47,
Drive all input ports.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
pavel_47
Voyager
Voyager
I don't remember the exact message, but there was a hint in error message to overcome the problem:
Add .tcl file that contains the following instruction:
set_property SEVERITY {Warning} [get_drc_checks UCIO-1]
in the 'pre' filed in the section, related to bitstream generation in implementation settings.
hongh
Hi, @pavel_47 ,
You can try the below command after opening the implemented design:
set_property BITSTREAM.General.UnconstrainedPins {Allow} [current_design]
write_bitstream XX.bit
florentw
Hi @pavel_47 ,
One solution is to edit the wrapper automatically generated to "disconnect" port between the top level and the BD.
However, as @dpaul24 mentioned, you need to connect the inputs to something (you can drive them to 0 or 1). The outputs can be unconnected in the top level wrapper
Florent
