How to add RTL code to Block Design
Hi All,
Is there a way to add RTL code to Block Design without creation a Custom IP? As far as I know the RTL hierarchy should be created with the 'RTL' sign inside of the block (as it's shown below).
Please describe the steps of adding RTL code to Block Design.
Thank you!
hi,
refer to chapter12 of this document.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug994-vivado-ip-subsystems.pdf
--hs
check this ARs
http://www.xilinx.com/support/answers/57546.html
Thanks and Regards
Balkrishan
@dmitry1417,
Refer to page 16 of this link: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug994-vivado-ip-subsystems.pdf
Nupur
