How to add existing vhdl modules in vivado HLS project?
I am starting a new project on ZC702 board and Vivado.
Newbie to ZC702 and to Vivado.
Moderate experience in VHDL and ISE.
I want to re-use some VHDL modules that are well-tested from similar projects.
I haven't found anything that explains how to instantiate and connect VHDL modules to HLS modules, top-level or otherwise.
Can someone point me in the right direction?
Emmett
Hi @emmettbradford,
If you are using HLS then C,C++ files can be given as an input and the generated files are .vhd or .v files which can be exported to Vivado in the form of IP, dcp etc. for later flow such as implementation.
If you are having VHDL files then you can use it in Vivado directly.
You can go through HLS tutorial http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug871-vivado-high-level-synthesis-tutorial.pdf
Let me know your requirements to help you.
Arpan
@emmettbradford,
You cannot give RTL files as input in Vivado HLS.
However you can package your C code in HLS into an IP and then use that IP along with your VHDL code in Vivado.
Nupur
Hi Nupurs,
Thanks for the speedy reply!
I see.
So the top level must be VHDL.
I suppose that means that the HLS module must be a separate project, and the VHDL output copied into the other VHDL project?
Do I establish the ports in HLS?
If so, how?
Or do I wait and do it in the VHDL output?
I have been looking for info on these issues.
Can you point me to some ug*.pdf or other resource?
Emmett
Hi @emmettbradford,
Arpan
OK.
That should get me going.
At least I know what I am supposed to be trying to do.
Emmett
The interface of my VHDL modules is AXI but also discrete signals and vectors.
Isn't there a way to "package" my vhdl modules as "IP" that can then be used in Vivado HLS?
Please list the best search terms.
Emmett
Hi @emmettbradford,
HLS Input is C,C++ files whereas o/p is IP,dcp which can be used as an i/p to Vivado.
I didn't get your query correctly. You can use VHDL file in Vivado along with the Vivado HLS IP.
Please post your query in HLS board to target correct audience.
Arpan
Emmett
