ldm.eth
How to change a name of Debug Unit (ChipScop/ILA)?
Hi All,
How is it possible to change a name of Debug Unit (ChipScop/ILA)?
Thank you!
tedbooth
In IP Integrator, select the ILA block.  To the left of the canvas, there should be a "Block Properties" window.  In that window, there should be a "Name:" field.  You can enter a new name there.
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
