Visitor nmpr
How to load verilog include file
I am trying to load a big verilog design into FPGA using ise 9.1 .
Some verilog file used  an `include declaration for files.
When I synthesis the code, the tool can not find these files.
I have try to load these file directly into use but the tool refuse.
There should be a way a declare a search path so the tool can find and use them.
What is the best way to solve this issue.
nitzan
Participant jared.chen
Re: How to load verilog include file
There is  an option named "Verilog Include Directories" in Synthesis Properties.
Verilog Include Directories (Advanced)
Specifies the discrete paths to your Verilog include Directories. To specify multiple paths, type in multiple paths, using the pipe (|) symbol to separate each path. You can also click the Browse button to browse to the first path and type in subsequent paths, using the pipe (|) symbol to separate each path. There is no default.
Jared
Jared
Visitor nmpr
Thanks for the reply.
This does solve the problem using the ise!!
How can I declare it in a TCL script?
Nitzan
project set "Verilog Include Directories" directory_path
