How to merge two projects quickly?
I wonder if there are some methods to merge two projects into one quickly? Just like Packaging a project into an IP core and add it into the other project?
Hi Raj,
You really solved my question.
Xz
Hi xzwang@hnu.edu.cn ,
By "two projects" you mean two separate FPGAs in one project or both projects on same FPGA?
If on same FPGA,  keep the two projects separate in a source-code  repository. Then create a Vivado project and "include" the sources for those two projects in the project. Create a top-level source to instantiate those two projects.
Raj
Hi Raj,
Xz
Glad to know that the information was helpful.
Do you have further queries on this? If not, please close this thread by marking it as accepted solution.
Raj
