dxdanielson
How to trigger a process on the rising edge of any of multiple inputs.
I’m writing VHDL for a Xilinx CPLD and I need to trigger a process on the rising edge of any of four different inputs.
The following doesn’t work, but it shows what I want to do.
If (rising_edge(in1) or rising_edge(in2) or rising_edge(in3) or rising_edge(in4)) then…
Any of the inputs may be high or low when there's a rising edge on another.
Any ideas?
sonicwave
I have only very little experience with CPLDs, so I'm not sure this will work. But if you have a fast enough clock available, you could simply continuously sample the four signals, compare each of them to their previous value, and trigger the appropriate statements if a change is detected.
Without a clock, if you can get a delayed version of the four inputs, you might be able to XOR the current and delayed versions, do an OR on the results, and use that as a clock?
eilert
you are trying to do somthing weird, but with the limited ressources of a CPLD one has to be "creative" sometimes. :-)
The problem is that the synthesis tool just don't understands your synchronous description.
(There can only be one clock in a synchronous description for a process)
My first intention was to recommend something like this:
ff_clk <= in1 or in2 or in3 or in4;  -- concurrent assignment outside the process
if rising_edge(ff_clk) then...
Synthesis will accept it, but this will only work when you have short pulses which do not overlap. Can you guarantee that?
If your signals have a more randomly character you may have to rethink your approach.
Maybe it's helpful to draw a sketch of how you would solve the problem with ordinary gates and FFs.
You will quickly see that it's not trivial to find a generic solution.
Have a nice synthesis
  Eilert
sonicwave
dxdanielson
Interesting. I didn't realize you could use 'event on a combined signal. But it makes sense. Unfortunately I'm looking at a quadrature signal so there is overlap in the pulses.
dxdanielson
Here' s a code snippet of a working solution.
if (rising_edge(clk)) then
      s1curr <= s1;
      s2curr <= s2;
      s3curr <= s3;
      s4curr <= s4;
      s1prev <= s1curr;
      s2prev <= s2curr;
      s3prev <= s3curr;
      s4prev <= s4curr;
      if ((s1curr = '1' and s1prev = '0') or
          (s2curr = '1' and s2prev = '0') or
          (s3curr = '1' and s3prev = '0') or
          (s4curr = '1' and s4prev = '0')) then    -- a rising egde one of of the four step inputs was detected.
