I want to open a future version Vivado project with an older version
*I have a 2016.3 Vivado project. But, I need to open it with 2013.4 Vivado. I tried to directly open an 2016.3 project with 2013.4 Vivado. But it was not opened.
*I try to create a new project in 2013.4 and add all IPs step-by-step. Probably version of some IPs in design changed. but those are not big problem. I can change them manually.
*Especially Zynq PS -reconfiguration in a new project may be difficult. Because there are many parameters in Zynq PS.  Is there a way to generate(export) a configuration file of Zynq PS? thus, I can basicly show that generated file to Zynq PS in 2013.4.  I have seen button "import xps settings" in Zynq. Is this button for above purpose ?
*And the most important one is that is there Zynq support in Vivado 2013.4  ? Because I can not find Zynq PS System in ip catalog of Vivado 2013.4.
Best Regards,
Tags (2)
Re: I want to open a future version Vivado project with an older version
Zynq devices are available in Vivado 2013.4 and the IP catalog contains the following processor IP
- Microblaze
- Microblaze MCS
- ZYNQ Processing System
I don't think this can be supported.
You are venturing off road by trying.
Why do you need to do this?
Keith
Dear @klumsde,
*In order to be able to directly use the SW of the this app note (XAPP741). App note reference design in 2013.4. All SW (Microblaze) and HW files provided.
*I constructed the same app note in 2016.3 for a Zynq. Many of the IPs are upgraded to new versions. Therefore, drivers of those new version IPs are also changed. So, app note SW could not directly use with Zynq and many new version IPs in 2016.3.
*I want to use SW files with Zynq directly or with a minimum change.for this reason, I try to construct app-note for Zynq in 2013.4 . but Zynq is not seen in 2013.4 IP Catalog. Am I wrong?
Best Regards,
Tags (2)
- Microblaze
- Microblaze MCS
@howardp,
Sure. Due to selected part number (a Kintex), Zynq is not seen in catalog. Now, it is seen for a selected Zynq part.  But It is need to manually configure the all Zynq parameter again in 2013.4. Beacuse, an exported configuration file (from another Zynq project)  could not be imported to Zynq in 2013.4.
Tags (2)
