IP Packager: Customization Parameters Editable
Using 2017.4 on Win 10 x64 and trying to package an IP, I want to have a dependency for one parameter. The dependece is made by comparing a string: $CLK_SELECT == "EXTERNAL", but I get this error:
Errors found in enablement expression ($CLK_SELECT == "EXTERNAL"): wrong # args: should be "isTclExprValid CLK_SELECT"
Can someone help me with this issue?
Giovanni
Hi @gnntcz ,
Refer to UG1118 creating & packaging custom IP >> setting an enablement expression.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug1118-vivado-creating-packaging-custom-ip.pdf#page=24
Also, EXTERNAL should have "$" prefix before the variable name as mentioned in the UG1118.
https://www.xilinx.com/support/answers/65277.html >> step-3 shows how to set port dependencies.
Hope this helps.
Ansari Hunen
