ISE 11.4 RTL Viewer not updating all connections
A question about the net connections on the RTL viewer.
If a connection / bus is directly connected to another component or bus the viwer corrcetly displays the connections.
However if the same connection is made through a case or if statement the connections dissapear.
Has anyone else have the same issue?
Any help would be great
Justin
Solved.
Next menu item down Technology Schematic displays all connections correctly.
Solved.
