Accepted Solution
ISE 12.3 crashing on 'file open'
Re: ISE 12.3 crashing on 'file open'
I just installed ISE 14.6 on Windows 7 x64 Professional, and I'm having the same problem:
1. I click Run for Configure Target Device in Project Manager
2. it says no iMPACT project is found, so I click OK to open iMPACT
3. in iMPACT I click Open Project, then choose one of the projects I created previously.
4. As soon as I click OK to load the project in the dialog box, iMPACT crashes with message "_impact4.exe stopped working.
I followed nachum's instructions (renaming dlls), however the problem persists.
Any ideas?
Solved the problem for 10.1 on Windows 7 by editing the windows path variable
form
%XILINX%\bin\nt64;%XILINX%\lib\nt64;
to
%XILINX%\bin\nt;%XILINX%\lib\nt;
then starting ISE 32 bit version from start menu.
I also started windows service WebClient.
Not sure that you have to do that.
I had to switch it on to run the simulator from windows command line.
:'3 Thanks! you are god!
This is the first time I write in this forum , but I have to thank you Howard for the solution you privded.  It still helps people in 2015!
Thank you howardp.
I am using Xillinx 14.7 ISE Design Suite.
The first step worked fine for me.
Now i am able to use the option "add source".
Thanks for your post   :)
Mihir Gajjar.
Thank you so much. Worked for 14.7 on windows 10!
Just wanted to let the thread know that in Windows 10 x64 (latest updates as of November 21st, 2015) the libCompatibility.dll fix worked on all versions 14.2 and above.
Thanks so much! This had me tearing my hair out for days. Nice to search for a problem and immediately find the correct solution!
PS No edit post feature in this forum?!?! Crazy. Had to delete and re-post to fix a single letter mistake.
Thank You, my ISE version is 14.7 and Windows 10 but the 1-th step helps me!
This bug is known since 2010 and still present in 14.7! Unbelievable! May you guys shut stop saying thank you, otherwise, Xilinx may never fix that bug ;-)
