ISE: Cannot use "Open Project". Have to use "New Project"
I have used both ISE Design Suite 14.6 and 14.7. Both of them don't allow me use "Open Project" to reopen an existing project. Every time I re-open the software, I have to use "New Project" to create a new project and then copy all source files over. If I use "Open Project", the ISE Design Suite will close itself. Anyone has this experience or know how to solve this problem?
Can you specify your operating system ? This issue seems to be OS specific.
Please check below AR
http://www.xilinx.com/support/answers/38474.html
Ashish
Moving to Design Entry board. This board is only for Simulation based queries.
Debraj
Windows 8.1 x64
Windows-8 is not a supported OS for ISE tools.
Please refer to page-7 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_5/irn.pdf for details on supported OS.
If you face the same issue when working on supported OS, let us know.
Deepika.
Deepika.
