Visitor hadi_alik
ISE Maping Error bypassing
Hi all
I have bought a Spartan-3E board with all accessories but, when I want to just test the board with simple example: "Default Xilinx CPLD Design" from  http://www.xilinx.com/products/boards/s3estarter/reference_designs.htm  for Xilinx receive the following series of error when I try to map the code:
ERROR:MapLib:30 - LOC constraint P23 on A<24> is invalid: No such site on the
device. To bypass this error set the environment variable 'XIL_MAP_LOCWARN'.
ERROR:MapLib:30 - LOC constraint P2 on XCF_CE_B is invalid: No such site on the
I set the variable but I actually seems illogical suggestion to by pass the the error, not to solve it?:robotsurprised:
Any Idea?
Cheers
Hadi
Message Edited by hadi_alik on 05-20-2009 03:09 AM
Message Edited by hadi_alik on 05-20-2009 03:10 AM
Visitor hadi_alik
Re: ISE Maping Error bypassing
Thank you
It is already solved. The problem was due a space in the name of files and directories.
hadi_alik wrote:
Hi all
Any Idea?
Cheers
Hadi
Historian
Historian
hadi_alik wrote:
Hi all
Any Idea?
Cheers
Hadi
So why are you using the CPLD example design in an FPGA starter kit?
-a
Visitor hadi_alik
Thank you
hadi_alik wrote:
Hi all
Any Idea?
Cheers
Hadi
I have the some problem.Please tell me what can i do?
Visitor hadi_alik
It is already solved. The problem was due a space in the name of files and directories. Just check if there is any space in the names of path direectory or file.
Newbie superlode
or if the pin names themselves are named ok
