ISE doesn't work after a crash.
Hi all,
I have this problem, yesterday Project Navigator (ISE8.2) crashed while opening a project, a serious crash, the system was restarted automatically. I tried to open the project again, and PN crashed again, this time without restarting the computer, but I got messages like "The memory cannot be read ..." etc. etc. I tried again to open the project, this time no errors, but it seems that the project file is damaged, the project is not loaded, I get only some strange characters in the Sources Pane. Now this happens also with other projects. Of course I'm sure that the projects are good, I tested them on a different computer. In few words, ISE is not working anymore on this computer.
I got this problem in the past with ISE7.1, the solution was to format the PC, even removing and reinstalling ISE didn't solve the problem. I really would like to evitate formatting the computer this time, any hints?
Regards.
Thank you very much, it seems that this was the problem.
Hi Nemesis,
Please examine the Environment Variables is right or not. You can check it in XINFO report. The XINFO report is produced by using the XINFO System Checker software that is installed as an application with the ISE design tools. If in Windows, go to Start -> Programs -> Xilinx ISE -> Accessories -> Xinfo System Checker.
XILINX and Path should point to the ISE install directory. Example:
Path: d:\Xilinx\10.1\ISE\lib\nt;d:\Xilinx\10.1\ISE\bin\nt;d:\Xilinx\10.1\EDK\lib\nt;d:\Xilinx\10.1\EDK\bin\nt;
XILINX: d:\Xilinx\10.1\ISE
If the variables are wrong, please reference AR #11630 - Install - How do I check or manually set environment variables?
http://www.xilinx.com/support/answers/11630.htm
If this does not resolve your problem, please open a web case and attatch the xinfo report.
Jared
Please try to remove the files in this diretory:
C:\Documents and Settings\<your name>\Local Settings\Temp
ISE sometimes will store data here. Removing temp files sometimes helps.
