Visitor lsotoc2
ISE in-depth tutorial
Hi:
I am trying the ISE in-depth tutorial for Version 11.1. I installed the wtut_vhd and started the tutorial but on page 22 the Device Property window does not provide the Simulator: ISim (VHDL/Verilog) option. Also on page 25 when you are asked to add a file by browsing and selecting the time_cnt.vhd file from the project directory the file is not in the directory. If anybody experienced these problem before and can some help it will be greatly appreciated.
Re: ISE in-depth tutorial
Went through the tutorial earlier and did not encounter any of these issues. As shown in Figure 2-3 on page 22, is there a Simulator option in the dialog box? The time_cnt.vhd is also present. Please find the HDL (vhd) files for the tutorial attached.
Visitor lsotoc2
I found that that the ISIM was not showing in the pulldonw becuase my environment (Windows 7 64bits) will not be supported until ISE 12.  The workaround has been to run the 32 bit version of ISE 12.  I will check the tutorial again to verify the rest. Thank for your support.
