xl600
ISE synthesis always fails under Linux but not under Windows
I am trying to implement multiple ISE 8.1i designs under OpenSuse 13.1 that have been working under Windows XP ISE for many years.  When I attempt to run the synthesis process at any level on any design, the console results report no errors.  Yet, "Process 'Synthesis' failed" is always reported.
I suspect this is an installation issue or a Linux compatibility problem since there's no design issues with any of the 5 (Again, already implemented and working for over a decade using the Windows XP ISE of the same version) FPGA designs I'm trying to replicate.  My suspicion is that xst may not be returning a good status to ISE, even though the synthesis process is successful.  But that's only a guess...
I have installed and tried both the 32bit and 64bit versions of ISE, with the same results.
Does anyone have any suggestions or experience with this?
Thank you,
XL600
Tags (3)
xl600
Update:
If I run xst from the command line on the generated design.xst script, synthesis returns exit status 0. ISE should not be reporting failed.
xl600
Just in case... I'm using ISE 8.1i SP3
