Participant jpnaude
Is there a way to create an ISE project with the VHDL sources specified in the .prj file?
In our design we're at the stage where we need to experiment with Partitions to reduce implementation times. Our design environment is HDL Author which produces as output everything needed for XST to produce a netlist, that is:
- .prj file
- .xst file
- .bat file that runs synthesis with the correct command line arguments
However since we want to use partitions it seems like the only way to do that is through ISE by selecting the HDL files and assigning partitions to them (if there is a way to do this through a XCF please let me know, but according to XAPP918 it is not possible, or at least it looks like it). The project is quite big with loads of VHDL files all specified through the .prj file.
Is there a way to create an ISE project with the VHDL sources specified in the .prj file? Maybe using the tcl interface? I'm going to experiment with this now, but it there is an easier way please let me know.
Thanks in advance,
Jaco
