Issue to generate set-of-output context in KCU105 while implementing 'TANDEM PCIE WITH FIELD UPDATES'
   I'm planning to implement 'TANDEM PCIE WITH FIELD UPDATES' in Zynq MPSoc board. So, started to do a demo in KCU105 board by following the steps mentioned in the video link
https://www.xilinx.com/video/technology/tandem-with-field-updates-pci-express.html
   @ 9.52, he is running set-of output context synthesis and running the synthesis for the application hierarchy. I'm using Vivado 19.1, when I tried to do same, set-of-output context was greyed and unable to run the ooc synthesis. Thereafter, he is getting a dcp file for the application hierarchy and using that dcp file in TCL script files.
My queries are :
1. I'm not getting ooc for synthesis option for application hierarchy.
2. I'm getting dcp files for each modules that are implemented in block diagram comes under application hierarchy. As I'm having different types of many dcp files how do I need to declare that in TCL script file?
   I got stuck at this point. Anyone please help me whether it is due to tool upgrade and how to proceed further in vivado 19.1.
Re: Issue to generate set-of-output context in KCU105 while implementing 'TANDEM PCIE WITH FIELD UPDATES'
   Anyone please reply and help on this.
Hi @sumaiya ,
Check this it may help.
https://forums.xilinx.com/t5/Design-Methodologies-and/Vivado-Disabled-quot-Set-as-out-of-context-module-quot-menu/td-p/382661
https://www.xilinx.com/support/answers/60075.html
hemangd
