MIG clash
Accepted Solution Solved
Accepted Solution
MIG clash
Hello.
I have begun to use Vivado2017.1 in Windows10.
HoweverI am troubled very much because MIG does not work.
Please watch an attached file.
1. Create New Project. Device is Kintex-7.
2. IP Catalog - Generate MIG IP
3. ”Next” Button Click
4. MIG Clash
I need your help.
Thank you.
Re: MIG clash
Hello.
My problem was settled in Vivado 2017.3.
Thank you.
All Replies
Re: MIG clash
Hi @mac004
Refer the following URL. (AR #67168)
https://www.xilinx.com/support/answers/67168.html
It seems well-known issue.
Thank you.
Re: MIG clash
Hello watari-san
Thank you for a reply.
I knew AR.
This AR is written about "Browsebutton.
HoweverI am troubled with "Nextbutton of the beginning.
Sincerely,
Re: MIG clash
@mac004 You better off drag/drop the memory from the Board pane as it will apply the defaults for you.
Re: MIG clash
It seems few issue reported on MIG crash in Vivado 2017.1 . I would recommend to use vivado 2017.2 or 2017.3 release. It will help you to fix this issue
Thanks and Regards
Balkrishan
Kudos: 794
Solutions: 1,018
Re: MIG clash
This issue is seen on windows-8 and 10 platforms. Please generate the IP on a different machine (windows-7) and use it on the failing machine.
Deepika.
Re: MIG clash
Thank you.
I try Vivado 2017.3.
Sincerely,
Re: MIG clash
Hello.
Thank you.
