MMCM allows only 7 output frequencies
I am only able to generate 7 clocks by one MMCM. I want more than 7 clocks for my design. Do i need to use another MMCM. Is there a way so that i can generate more than 7 clocks from one MMCM only.
Re: MMCM allows only 7 output frequencies
yes you can use multiple MMCM
check this post as well
https://forums.xilinx.com/t5/General-Technical-Discussion/How-to-Synchronize-clocks-between-multiple-MMCM/td-p/567146
Thanks and Regards
Balkrishan
mmcm supports Output clock frequencies up to seven maximum only . you can use clock divider circuits
Thanks and Regards
Balkrishan
Is it ok to use two MMCM's.
Thanks and Regards
Balkrishan
@hulk789
You need to use multiple MMCMs if your design have more clocks. Also, refer the 7 series clocking user guide for more details:
http://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf
Anusheel
Helpful answer -> Give Kudos
Teacher muzaffer
I'm curious why more than 7 clocks are necessary, would you mind describing the design a little?
I have input 10Mhz clock.
I want to generate 40Mhz clocks with phase 0 , 180
20 Mhz clocks with phase 0,90,180,270
10Mhz clocks with phase 0,45,90,135,180,225,270,315
If i give clkin(same clk) to two MMCM will they be synchronized
When i tried to use 2 MMCM
Issues faced:
1. [DRC 23-20] Rule violation (UCIO-1) Unconstrained Logical Port - 1 out of 13 logical ports have no user assigned(This is for the clkin signal)
2.Not enough BUFG's inside FPGA
