Observer wonderwizard
Map fails after fresh SVN checkout
I have a 'working' ISE design which includes some top level HDL and a EDK design.
When I checkout from svn the design into a new/fresh windows directory it generates black box map errors during sythesis and map fails as you would expect.
When checking out the design from SVN to a new directory I have to manually change the EDK module search path in the .xmp file.
My first thoughts were that the EDK project was failing to build the RTL needed, hence the blackbox warnings from ISE?
*.make file looks ok, right paths etc
*_incl.make has some old paths some new paths.
SIMGEN_OPTIONS = -p $(DEVICE) -lang $(XPS_HDL_LANG) -intstyle $(INTSTYLE) $(SEARCHPATHOPT) $(BRAMINIT_ELF_SIM_FILE_ARGS) -msg __xps/ise/xmsgprops.lst -s isim -X C:/OLDPATH
Question 1:
Where has EDK picked up the old paths from to add to the _incl.make file?
Question 2:
Is there a way round this trouble of fixed paths?
Cheers,
Re: Map fails after fresh SVN checkout
More digging...
starting with a clean SVN checkout, two options, one works, one doesn't.
If a)
I open the ISE project and start synthesis the tool will fail as before.
If b)
open ISE project, open the EDK project, then close both. Design will synthesise correctly on the second time of opening.
Perhaps this is a bug or perhaps it is expecting too much of ISE....
It looks like the iseproject folder does not get updated until you exit ISE.
case a)
/iseconfig/*.projectmgr contains references to the original directory as put into SVN
case b)
/iseconfig/*.projectmgr is nice and clean with the correct paths.
Sorry, ISE 14.6 32bit version.
More digging...
If a)
If b)
case a)
case b)
