Observer ssong94
Missing board file for zc706
I'm using vivado 2015.4, I have zc706 board file in my <vivado_path>/2015.4/data/board_file but I couldn't found the zc706 board file on the GUI, thus alternatively, I try to use the same board part which is xc7z045ffg900-2. I am able to find this board part but when I'm trying to create project based on this part, an error as shown in the picture occurred. Anyone know how to solve this?
Re: Missing board file for zc706
Hi @ssong94,
The possible reason is that you installed vivado webpack edition. The ZC706 should not be inside.
Try to install Vivado system edition.
Hi @ssong94,
Observer ssong94
Thanks for the help. I updated my Vivado into system design version and now zc706 appears in the GUI.
