hzchen_umec
Missing xdc file inside user IP on a board design project
The situation is like this. I have generated two user IPs in a project.
After creating a board design, I instantiated both these two IPs. However at synthesize step, I get a error information which says a XDC file is missing when synthesize one of the IP.hzchen_umec_1-1618540609175.png
The required XDC is not user defined, more like a auto-gen file by Vivado.
I checked the other IP folder and found the xdc file is generated successfully.
Any solution to address this issue?
