Newbie cardona
NgdBuild:604 - logical block
I was trying to use the FFT IpCore from Xilinix, but I get an error, SO I began with simple basis to understand what was going on.
Now I have the simpliest code ever and I have the same error, and I've been trying to solve the issue reading forums but I haven't found a solution
My actual code is using a counter and using a top-level block to instatiative.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.all;
entity top_level_FFT is
port(
clock : in std_logic;
dout: out std_logic_vector(7 downto 0)
end entity top_level_FFT;
architecture arch of top_level_FFT is
begin
COMPONENT c_counter
PORT(
clk : IN std_logic;
q : OUT std_logic_vector(7 downto 0)
END COMPONENT;
Inst_c_counter: c_counter PORT MAP(clk => clock,q => dout);
end architecture arch;
and I have this error,
ERROR:NgdBuild:604 - logical block 'uu1' with type 'c_counter' could not be   resolved. A pin name misspelling can cause this, a missing edif or ngc file,   case mismatch between the block name and the edif or ngc file name, or the   misspelling of a type name. Symbol 'c_counter' is not supported in target   'spartan6'.
Thanks for your help,
Re: NgdBuild:604 - logical block
The message means that the netlist that you provided to ISE includes a module c_counter and the netlists did contain the contents of this module nor was there a NGC file or EDIF file that matched the same name.
So, where in your design is the c_counter module contents defined?
