[OPT 31-30] blackbox xbar not found
in my project I have 8 AXIDMA blocks connected to the ACP port of the PS through an axi_mem_intercon.
Systhesis is fine but then I receive the error
ERROR: [Opt 31-30] Blackbox AXI_FFT_i/axi_mem_intercon/xbar (AXI_FFT_xbar_0) is driving pin D of primitive cell AXI_FFT_i/axi_mem_intercon/m00_couplers/auto_pc/inst/gen_axi4_axi3.axi3_conv_inst/USE_WRITE.write_addr_inst/S_AXI_ACACHE_Q_reg[3]. This blackbox cannot be found in the existing library.
I attach the tcl to regenerate the design and the synthesis and implementation logs.
Any suggestion?
Max
Re: [OPT 31-30] blackbox xbar not found
I instantiated the interconnect module manually, then run the automatic connection and now I am able to complete the implementation.
Hi max.giacometti@gmail.com,
Refer to this link and check if it helps:
http://www.xilinx.com/support/answers/59335.html
Also check if you have a valid license for the IP.
Nupur
Accept as solution if it resolved your query, give kudos if it led you to the solution.
Nupur
Log has one blackbox module "AXI_FFT_xbar_0", but the shared file has no information on the commands and flow. Looks like opt_design is not able to find the black box module and hence showing an error.
Anusheel
Helpful answer -> Give Kudos
Anusheel
I checked the AR, but that seems to be valid for user defined IPs, while the xbar is included in the axi_interconnect automatically generated while connecting ACP and DMA.
So might it be a licencing issue?
I am using vivado webpack edition and I didn't purchase any licence. The AXI interconnect page states that the IP is Included at no additional charge with Vivado and ISE Design Suite.
Or is there a maximum number of ports which can be connected for free?
In another project I have 2 AXIDMA connected to ACP through AXI interconnect and the implementation process is successful.
