Scholar beandigital
Package IP with a custom interface
I have some IP with a set of signals (addr, data and we). They all start with reg_. Is it possible to create an interface for them like you can do with AXI? Then I can just connect them together from one IP to another without having to connect every signal.
Re: Package IP with a custom interface
Hi @beandigital,
Yes this is possible:
-> If you are using IP Integrator, you can use an already defined interface or create your own interface. See ch.4 (an ch.5 to create a new interface) of UG1118:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug1118-vivado-creating-packaging-custom-ip.pdf
-> If you are using the feature Add module to add a HDL file (from 2016.1), you can use the attribute X_INTERFACE_... : see UG994 p170:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug994-vivado-ip-subsystems.pdf
Hope that helps,
Florent
Florent
Hi @beandigital,
Hope that helps,
Florent
Florent
