Problem in connecting two blocks in schematic entry
Hi!
        I got 16 bit data coming  out from 4 four bit latches , LD4(assume them be larch A, Latch B, Latch C and Latch D). I combined latch A and B to get 8 bit data and similarly latch C and D to get another 8 bit data. I need to compare these two 8 bit data using 8 bit comparator COMP8 (comparator from symbols). My problem is I don't know how to make connection between the individual data lines coming from latches to 8 bit input data bus in the comparator COMP8. Can anyone help me solve this problem?
