Visitor noza
Re: Vivado internal exception
I am experiencing a similar error, but my problem is happening on RHEL6.5.
My output error log looks as follows:
  1 #-------------------------------------------------------------------------------
  2 # Vivado v2014.2 (64-bit)
  3 # SW Build 932637 on Wed Jun 11 13:12:34 MDT 2014
  4 # Current time: 8/15/14 3:37:31 PM
  5 # Process ID: 23706
  6 # Platform: Unix
  7 #
  8 # This file is an indication that an internal application error occurred.
  9 # This information is useful for debugging. Please open a case with Xilinx
 10 # Technical Support with this file and a testcase attached.
 11 #-------------------------------------------------------------------------------
 12 8/15/14 3:37:31 PM
 13 java.lang.NullPointerException
 14   at ui.PlanAhead.l(SourceFile:437)
 15   at ui.PlanAhead.a(SourceFile:72)
 16   at ui.cQ.run(SourceFile:425)
 17   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
 18   at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:733)
 19   at java.awt.EventQueue.access$200(EventQueue.java:103)
 20   at java.awt.EventQueue$3.run(EventQueue.java:694)
 21   at java.awt.EventQueue$3.run(EventQueue.java:692)
 22   at java.security.AccessController.doPrivileged(Native Method)
 23   at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
 24   at java.awt.EventQueue.dispatchEvent(EventQueue.java:703)
 25   at ui.frmwork.a.e.dispatchEvent(SourceFile:75)
 26   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
 27   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
 28   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
 29   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
 30   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
 31   at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Can anyone help me resolve this so that I can try and use the Vivado design tools
N
When do you see this error?
check if this AR is relavant http://www.xilinx.com/support/answers/60477.html
Deepika.
Deepika.
Are you seeing this consistently? Try running the example design to rule out design specific issues.
Thanks,Vijay
Hi @noza,
Did you try the options given?
Thanks,Vijay
Newbie dinglin
An internal exception occurred after I finished downloading the  bit file,the ila kept refreshing itself,it seemed like the software had crashed 。
