Release date 2019.1
I've experienced problems with the 2019.1 docnav on a debian "strech" machine. (debian is unsupported, I know, not necessairy to tell me ...)
invoking docnav caused a SIGABRT without any further error information. I'm using the cinamon desktop environment, and it turns out this does set various environment variables with the intent to make all Qt applications to have the look and feel of gtk applications.
me@machine:~$ env | grep QT
QT_QPA_PLATFORMTHEME=gtk2
QT_ACCESSIBILITY=1
QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
This "platformtheme" being gtk2 causes docnav to sigabrt.
You can avoid this problem by any one of those:
  • setting QT_QPA_PLATFORMTHEME=fusion
  • setting QT_STYLE_OVERRIDE=fusion
  • or, invkoking docnav as "docnav -style fusion
Furhter there is an incompatibility with the libssl.so shared library. My work around is this:
cd DocNav/lib
mkdir off
mv libatk-1.0.so.0 libattr.so.1 libavahi-client.so.3 libavahi-common.so.3 libblkid.so.1 libbz2.so.1 libcairo.so.2 libcap.so.2 libcrypto.so.10 libcups.so.2 libdbus-1.so.3 libdw.so.1 libelf.so.1 libffi.so.6 libfreebl3.so libgbm.so.1 libgcrypt.so.11 libgdk-x11-2.0.so.0 libgmodule-2.0.so.0 libgraphite2.so.3 libgssapi_krb5.so.2 libgthread-2.0.so.0 libgtk-x11-2.0.so.0 libk5crypto.so.3 libkrb5.so.3 libkrb5support.so.0 liblz4.so.1 liblzma.so.5 libmount.so.1 libnspr4.so libpcre.so.1 libpixman-1.so.0 libplc4.so libplds4.so libpng15.so.15 libselinux.so.1 libsmime3.so libssl.so.10 libsystemd.so.0 libX11-xcb.so.1 libXau.so.6 libxcb-glx.so.0 libxcb-present.so.0 libxcb-render.so.0 libxcb-shm.so.0 libxcb-sync.so.1 libxcb-xfixes.so.0 libXcomposite.so.1 libXcursor.so.1 libXdamage.so.1 libXext.so.6 libXfixes.so.3 libXinerama.so.1 libXi.so.6 libXrandr.so.2 libXrender.so.1 libxshmfence.so.1 libXtst.so.6 libXxf86vm.so.1 off
ln -s /usr/lib/x86_64-linux-gnu/libssl.so.1.0.2 libssl.so
Community Manager
Community Manager
Re: Release date 2019.1
Hi @larice ,
This will be noted within the forums and we appreciate your work around and information for other users within the same environment.
Thank you,
Devin
Community Manager
Community Manager
Hi @larice ,
Thank you,
Devin
