Observer shiroyuki
Should I take care .Xil folder contents?
When I took something action for an IP provided by Xilinx on Vivado Block Design, e.g. double click to configure, even if the configuration was cancelled intermidiately, I got a following error at the synthesis.
"[Runs 36-527] DCP does not exist: <project path>/.Xil/Vivado-5470-<host name>/coregen/<ip name>/<ip name>.dcp"
What does the error means? Should user take care under such hidden folder '.Xil/'??
Re: Should I take care .Xil folder contents?
Hi @shiroyuki ,
Have a look into this thread. It may help you . https://forums.xilinx.com/t5/Design-Entry/Missing-folder-quot-Xil-quot-in-vivado-project/td-p/901978
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
User does not need to care about the .Xil folder.
There must be something wrong in your project.
Could you try disableing IP Cache?
Tools -> Settings -> IP -> IP Cache -> Select "Disabled" for Cache scope.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
雪はいつも白いですよね?
Observer shiroyuki
I had no change from the disabling.
Hi @shiroyuki ,
hemangd
