Observer shiroyuki
Should I take care .Xil folder contents?
When I took something action for an IP provided by Xilinx on Vivado Block Design, e.g. double click to configure, even if the configuration was cancelled intermidiately, I got a following error at the synthesis.
"[Runs 36-527] DCP does not exist: <project path>/.Xil/Vivado-5470-<host name>/coregen/<ip name>/<ip name>.dcp"
What does the error means? Should user take care under such hidden folder '.Xil/'??
Re: Should I take care .Xil folder contents?
Hi @shiroyuki ,
Have a look into this thread. It may help you . https://forums.xilinx.com/t5/Design-Entry/Missing-folder-quot-Xil-quot-in-vivado-project/td-p/901978
hemangd
User does not need to care about the .Xil folder.
There must be something wrong in your project.
Could you try disableing IP Cache?
Tools -> Settings -> IP -> IP Cache -> Select "Disabled" for Cache scope.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
雪はいつも白いですよね?
Observer shiroyuki
I had no change from the disabling.
Hi @shiroyuki ,
hemangd
