Simple VHDL Question - for Novice
Just bought a book on VHDL - i used to use ABEL in 1989 to 1991 - but then changed areas of work.
My question is - the book i have states the following as an example :
________
type memory_structure is array (0 to 255) of std_logic_vector(7 downto 0)
signal memory : memory_structure := (others => (others=>'0'));
Previous in the text, the book stated that signals will eventually become wires - i assume internal routing.
What i do not seem to understand is that if memory_structure is an array 256 deep and integer wide - how will this become a signal - will it just be 32 wires (32bits data width) ?, and each of the elements 0 to 255 can selected individually be passed along the 32 signal paths in sequence if so required  ?
Thanks and regards.
Richard.
Re: Simple VHDL Question - for Novice
Hi Richard,
all actual Xilinx FPGA Families have some amount of BRAMs.
These blocks are quite flexible and can also be used as FIFOs.
You should take a look at the Memory section of the CoreGen tool.
It's quite easy to create the desired FIFO IP-Core with it by just entering some parameters.
Have a nice synthesis
   Eilert
Hi Richard,
basically your textbook is true.
You have declared a set of names, that will be applied to some wires.
The question is: Where are these wires, and what is connected to them?
In your example you end up with 256*8 wires somewhere.
Now it depends on how you use the declared signal in your code.
In the best case you write some code that is recognized as a memory by the synthesis tool , and all the wires are sucked up by a BRAM.
In the worst case you are wasting a lot of FFs, or create a big combinatorical mesh with latches.
____
Actually in your example the required interface signal needs to be of byte width (7:0), not integer (31:0).
But thats just a detail.
The signal "memory" is just used to wire up the memory array.
You need another set of signals like:
signal Address : std_logic_vector(7 downto 0);
signal DataIn : std_logic_vector(7 downto 0);
signal DataOut: std_logic_vector(7 downto 0);
to access the memory.
And if everything works well, you will just see these signals in your design, connected to some BRAM block.
Take a look at the "Synthesis Constructs" in the ISE Language Templates how to write code that's recognized as a RAM.
  Eilert
Historian
Historian
@shadders wrote:
________
Thanks and regards.
Richard.
Well, yes, they become wires, in a sense. More to the point, though, it's an array of flip-flops.
Forget the width, for the moment and just consider a one-bit wide memory. To read or write any random bit you provide an address. For read. that address acts as a select for a 256-input multiplexor. For write, that address builds a clock enable for the selected bit. (For writes it probably helps to have a write enable.)
If you make this structure 8-bits wide, you simply replicate the above 8 times. If you want it to be 32 bits wide, the structure is replicated 32 times. All of that is somewhat hidden from you; you simply change the width of the range of std_logic_vector(WIDTH-1 downto 0) and it just happens.
Hi Eilert,
Thanks - this makes sense now - the BRAM is probably what would need to be implemented not to waste the flip flops - just getting back into this area of work - so will examine the various products that Xilinx provide.
My mistake on the integer - i realise now that 8 bits wide was stated in the example.
The addressing aspect looks important to remember - my intention is to implement a RAM based FIFO - if BRAM is available in the IC's that Xilinx provide - will make this aspect a lot easier - especially if 24bits or 32bits are easilly implemented. This is for an Audio DAC.
Thaks again for your help - much appreciated - i need to read more of the book - only on the first few chapters.
Thanks again,
Richard.
Hi Bassman,
Thanks - from you reply and Eilert's reply i can see the process of the design. I need to select my target device carfefully to ensure the design is more efficient.
Thanks again for your help,
Richard.
Hi Richard,
   Eilert
Hi Eilert,
Thanks - will be using the smaller CPLD or FPGA with lower pin counts such that BGA packages do not need to be used.
Richard.
Hi Richard,
please be aware that CPLDs do not have BRAMs!
  Eilert
