Sub-core references doesn't appear to like VHDL packages
I have several modules that are common across my design. I'm using IPI. After looking at posts, this one seemed to be the best for help to use/define sub-cores:
https://forums.xilinx.com/t5/Design-Entry/HDL-files-used-in-custom-IP-could-not-be-updated-Advise-please/m-p/864773/highlight/true#M17129
So I packaged up the directory  of common VHDL files as a sub-core and added it into the file groups for the IP I'm packaging. It shows up as a sub-core with the right library name. I try synthesizing it and it fails. A VHDL package in the library is not found. The error states that "use.mylibrary.component_pkg" has an error and "component_pkg" is not found in the library. When I look at the .xml file, it all looks right: the library name, the file names, the synthesis group, the simulation group, at least as far as I my limited knowledge can determine. I'm not modifying the .xml at all. In the IP in which I want to use the common files, the subcore reference shows up in the packaging>file groups as "xilinx.com:ip:mylibrary:1.0" in both the Synthesis and Simulation groups.
I'm using 2017.1 on Windows 10.
What am I missing or need to do?
Thanks for your help ahead of time and have a great weekend,
Charlie
@chuck_s   "A VHDL package in the library is not found."
Just a hunch, but try issuing the following tcl command before packaging your shared files as a 'library core' :
set_property source_mgmt_mode DisplayOnly [current_project]
You will probably also then need to repackage your IP that uses the 'sub-core reference' after making the above change.
EDIT (clarify) : This flag forces the Vivado IP packager to include all the source files, rather than omitting some that Xilinx's buggy source parser mistakenly thinks are unused, see AR 70646 :
" With this option, the hierarchy in the Vivado Hierarchy Source View will still be displayed based on the
" default value of generics and parameters, but all source files in the project will be sent to the IP packager.
To help troubleshoot, could you post the following:
'Library core' info:
  - VHDL code snippets of your shared package with the package header, and a declaration of a problematic item
  - screenshot of the IP Packager 'File Groups' page during the  'package as a library core' process
IP info:
  - VHDL code snippets of the IP library clause for the 'sub-core reference', and an instance of a problematic item
  - screenshot of the IP Packager 'File Groups' page during the packaging of your IP core
Top level info:
  - from your top level project, a screenshot of the "IP catalog"  tab showing your user repository with your IP core
-Brian
Tags (2)
IP info:
Top level info:
-Brian
Tags (2)
That was it.
Thanks for taking the time to look at this and offering a suggestion. I definitely appreciate your effort.
I've looked for that property on the forum and found this which I'm sure you know about:
https://www.xilinx.com/support/answers/69320.html
- Chuck_S
