07-18-2016 06:25 AM
I have a SystemVerilog (.sv) testbench that instantiates VHDL (.vhd) design files. In the testbench, I need to use a record defintion from a VHDL package file. When I try to import pkg::*; in the .sv testbench, Vivado gives an error during compilation:
xvlog -m64 --relax -prj sw_tb_vlog.prj INFO: [VRFC 10-2263] Analyzing SystemVerilog file "tb.sv" into library xil_defaultlib ERROR: [VRFC 10-91] pkg is not declared [tb.sv:3]
I changed the compile order in the Vivado window so the pkg.vhd file is compiled before tb.sv, however this error still persists. I've also tried `including the .vhd package file instead of importing, however that generates a syntax error as they are different language files.
Any ideas?
07-18-2016 07:12 AM
Hi @marver
Can you please post simple code that demonstrates your usage for better understanding?
07-18-2016 07:18 AM
Hi @vijayak,
Here's a snippet of tb.sv
`timescale 1ps/100fs import pkg::*; module tb; local_bus_record sys_ctrl_bus; //... endmodule
and here's a snippet of the pkg.vhd file
library ieee; use ieee.std_logic_1164.all; package pkg is type local_bus_record is record reg_ack : std_logic; reg_data : std_logic_vector(31 downto 0); end record local_bus_record; end;
07-18-2016 10:08 PM
Hi @marver
I am able to reproduce the issue with Vivado and seeing the same issue with Questa as well.
I will get back to you soon on this.
05-30-2017 07:22 AM
What was the solution/outcome here? I'm having an identical issue in 2016.2
04-14-2018 02:03 AM
Is there a solution to that problem yet?
and in general - how well xilinx tools work both with VHDL and Verilog/SystemVerilog files?
oft
