The memory peak means the maxium memory utiliztion?
Time (s): cpu = 02:33:48 ; elapsed = 01:34:07 . Memory (MB): peak = 11134.523 ;gain = 2854.418
Re: The memory peak means the maxium memory utiliztion?
Hello @m006,
It simply tells you how much memory (computer RAM) was used by each of the processes. It's pretty much meaningless, unless you are running on a machine without sufficient RAM.
If needed, the Vivado memory utilization table for the latest devices is located at: https://www.xilinx.com/products/technology/memory.html#overview
This table contains information on typical and peak memory usage.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Yes, Peak Memory is the maximum amount of memory which was used by the processes or sub-process that is being reported.
